 MCD Engine re-build
PostSubject: MCD Engine re-build   Fri Sep 10, 2010 2:14 am
Well FINALLY got my head into gear, to look at the 'BUTTER TUB' today (haven't so much as looked at it since the 'T' Party, as I was so mad at it)
To See if I could figure why it wasn't firing at the bash
Did loads of pre strip tests
Fuel down the plug (in-case it wasnt getting any due to a bad Carb)
Oil into the chamber (in-case the ring was leaking)
Change the Carb (Although it seemed to be fine)
Changed the insulator block an gaskets at the bash for a standard one (I run the alloy block an Teflon gaskets as a rule)
Re-set the coil gap (Although it was fine)
Checked for spark (Had a great spark)
But NOTHING banghead
Could I feck as like figure it out
Getting fuel
Great spark
Loads of compression
No visable Gasket leaks
Had a brew, watched some TV, chilled for an hour, an then took the engine out of the car
Stripped it, an STILL couldn't find anything banghead
Nothing wrong with the head (no scoring, an plating was fine)
Piston was fine
Ring seemed fine
Con rod bearings seemed fine
All Gaskets seemed leak free
So stripped off the
Clutch
Clutch carrier
Flywheel
An checked the crank case seals an bearing
There seemed to be a little slop in them, an the Clutch side one looked to be leaking very slightly
So stripped the Crankcase in half
An gave each side a little 'Wiggle'
The clutch side bearing seemed to have more play than the flywheel side
So I got out my spare engines, an spare crankcases an did a few tests
Trying 3 sides against each other
3 flywheel crankcase half's
3 clutch crankcase half's
An the clutch side crankcase off my current engine seemed the worst of the 3
So took the best of the other 2, an the best flywheel crankcase side
An built it all back together again
kept the current Gaskets (mainly as I didn't have any new ones), an due to the fact I wasn't holding out much hope of anything, as I was pretty down heartened with the whole thing currently
The Buggy is FAULTLESS, but I've been plagued with engine problems for an AGE now, Just one thing after another
So got it all built back up, put my alloy insulator block back on, an the Teflon gaskets
Same carb
Same coil pack, re-set the gap
same gaskets
same crank
Same piston an ring
Same head
Same fuel
Same EVERYTHING, baring that one half of the crankcase on the clutch side
Connected up the fuel lines (didn't put it in the car, didn't hold out much hope)
Primed the carb
Choke on
One pull ............. COUGH ............. affraid
Choke off
Second pull ......... FIRE ........... cheers .......... omgbanner TOTAL SHOCK
Hit the stop button ................ Ok, GRIN time very happy
put it all back into the Buggy
Nervously give it a pull .............. Fire first time ...............HOLY MOLY BATMAN
But reving very high, so wind out the idle screw, NOTHING, so not that
Richen up the low end, an that dropped it back nicely, so tune was out slightly, most likely due to the leak
Ok connected up the Carb slide, an the electrics an test the failsafe ........... Cool working fine
Took it out in the garden an its going GREAT GUNS cheers
So only thing I can think after this long winded essay of a post, is that the seal/bearing was loosing compression on the Clutch side of the crankcase
An that stopped it firing
as I haven't done, or changed anything else
Anyway, currently its working again, so My mood has lifted slightly, an I still love my buggy hug
Might NOT sell it now wink
PostSubject: Re: MCD Engine re-build   Fri Sep 10, 2010 2:18 am
Something so relatively simple as that ?
Yikes......
Really glad you've got it sorted though fella, Moo Cow felt lonely at the T Party, being surrounded by all them ass bandits, rofl
Now then - NO FIDDLING!!!!!!
british flag
PostSubject: Re: MCD Engine re-build   Fri Sep 10, 2010 2:29 am
Yikes......
british flag
Yeah your right bud
Simple as that ............. Bloody thing
does kind of pig you off a little
but I couldn't have sorted it at the bash (didn't bring the spare engine parts)
An to be honest probably wouldn't have had a chance to or got my head around it properly either
But what pigs you off more than anything,is It fired fine the time before the bash
Yet wouldn't even attempt at the bash
I was offered an engine to borrow, but with the MCD running the centre drive shaft under the engine, it would have ment cutting up someone else's engine just for a little rag around, an I wouldn't have done that
SODS LAW RULES union jack
But yeah, felt a little sorry for the lonely Moo Cow against all those Baja's lol
PostSubject: Re: MCD Engine re-build   Fri Sep 10, 2010 2:50 am
Thats great matey, but on another note its crap, or makes me feel crap lol I gave you it thinking it was absolutely fine and would mean you could just drop it in and have her up and running again, sorry
PostSubject: Re: MCD Engine re-build   Fri Sep 10, 2010 2:57 am
Don't be silly
Was working perfectly fine
An was when it went it
You know that you were there when it was fitted wink
Could have gone at any time so not your fault in the slightest
But seen as you feel bad about it, an now you've said it ........... I will let you make it up to me, in some creative an Kind way, an will now play on it at every available opportunity Twisted Evil Twisted Evil
PostSubject: Re: MCD Engine re-build   Fri Sep 10, 2010 3:29 am
FEMALE DOG! lol
I already have made it up to you by doing all this work to my car myself instead of making you do it lol
Sean
PostSubject: Re: MCD Engine re-build   Fri Sep 10, 2010 4:03 am
Why is it never anything simple when you take my engines apart! lol
Glad you go it sorted, just sucks you didnt get to run it at the T party
PostSubject: Re: MCD Engine re-build   Fri Sep 10, 2010 4:11 am
wol wrote:
FEMALE DOG! lol
Oh is that how you've made it up harhar harhar
That's cause your engine was full of ...............MUD, an metal shavings hahahaha
Yeah was a bugger that's for sure sad
banners
PostSubject: Re: MCD Engine re-build   Fri Sep 10, 2010 7:24 am
glad to hear it's feeling better, I've still only seen it run for about a hour in the whole of this year!
The next time I see utterly I'll dare to blink knowing I'm not missing it running wink
Merlin
PostSubject: Re: MCD Engine re-build   Tue Sep 14, 2010 1:25 am
Narrrrrrce one hosswald, glad to here the beast is running again mate! :D
carlcurtis83
PostSubject: Re: MCD Engine re-build   Tue Sep 14, 2010 3:23 am
Nice to hear it's sorted....my engine problems at the bash turned out to be half the field clogged up under the crankcase!!!
Damn HPI and their silly designs :lol:
View user profile http://www.facebook.com/home.php?#/group.php?gid=25941304238
PostSubject: Re: MCD Engine re-build   Tue Sep 14, 2010 3:47 am
laugh very happy rofl
a very common thing with the Badger Boys rofl
mixmasterjay
PostSubject: Re: MCD Engine re-build   Tue Sep 14, 2010 7:15 am
nice one mark so she is ALIVE again GOOD , its just a shame it was something that small and simple that stopped it running ,ah well atleast its sorted now aye mate
View user profile http://chilled-rc.net/forum/index.php?sid=852eacbfd982963fb777a9
MCD Engine re-build
» 5.3 LS Vortec Engine and 4L60E Transmission
» Having some fun with a baja bug engine...
» my custom 1/4a rc plane build log
» Cox Sky Cruisers Viper RC conversion build
» The James Hex-2 build log
