 serious engine probs :(
Go to page : 1, 2, 3, 4  Next
mixmasterjay
PostSubject: serious engine probs :(   Sat Jun 04, 2011 5:59 am
hi all , well ive rebuilt the engine today with a +2 stuffed crank ,new seals,new piston ring,new steel gaskets,and its still shafted lol , its blowing fuel/air out the carb and sucking through the exhaust , the piston mark is facing towards the exhaust port and the ring is sat right , compression is exellent,fuel lines on the right way ,spark is great but nothing , the airfilter is wet through with petrol so took that off to see what was going on and its spitting fuel out when i pull the pull start , so god knows whats up with it , its not flooded either
thanks for your help
jay
View user profile http://chilled-rc.net/forum/index.php?sid=852eacbfd982963fb777a9
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:10 am
Not sure on that one matey, on a normal engine that would I think be a timing problem but no idea on these, could it be you have scored the ring (very easy to do when installing a head) and therefore its not firing and flooding?
mixmasterjay
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:22 am
thats the thing though wol its not flooding and its sparking great , i thought it could be a timing problem but i can't see how the timing can change because of the where the woodruff key is and the way the flywheel goes onto it , it should always be the same timing , i just can't for the life of me what is happening lol
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:25 am
I know its patronising but are you deadly sure the piston is on the right way round, I can only think its that
mixmasterjay
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:29 am
yeah the mark towards the exhaust port , the split towards the carb
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:34 am
Bloody hell you don't have much luck bud
sounds to me like your carb may well be up the spout
Like the diaphragm is getting the fuel from the lines, but then not sending it to the engine
this could be something as easy as a blocked jet
which I highly suspect
You can get replacement carb jet kits, but I would suggest giving another carb a go, before you even think of spending any more money
Timing wise, other than spark gap you can't get it out
There are adjustable coil covers, that alter the timing, an you can get differing profile woodruff keys, both of which I know you've not got, so they, an the timing can be ruled out as a problem
As Wol has said, an I know its a daft seeming thing, but having also done it myself when building engines
Did you get the piston round the right way?
You can easy check if you have, remove the carb, look through the Inlet window, an rotate the crank, if its the right way, you will see the piston ring gap come to the front of the in the Inlet window
if all is good, an I suspect it will be
Then it just screams Carb problems to me
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:38 am
It does sound like carb for the fuel, but that wouldn't explain the suck puff reversal would it?
It only takes quickly chating to someone and the bugger goes on backward lol
mixmasterjay
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:44 am
yeah the piston is in the right way , the spot is facing the exhaust port and the ring split (twss block) is facing the carb
the air comes out the inlet port even when there is no carb on and the exhaust port sucks slightly , now the carb isn't on so it can'#t be a carb prob in that respect and there is more than enough fuel comming out the carb , its all getting blown out into the filter
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:46 am
But its Not feeding the engine
So it has to force it somewhere
the reverse puff, is just the normal created pressure being fed back
I highly doubt its actually sucking an blowing in reverse
Just seems that way, as instead of blowing the fuel into the engine as it should be
Due to the blocked Jets, its being forced out the only way it can find
In this case, most likely the choke lever shaft
Strip the carb top off, there is a very small filter in there, an also a breather hole at the side of the white plastic, that can sometimes get blocked with dust an crap, as can the upper filter under the diaphragm
All worth a check
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:47 am
Have you got the right gasket thickness on for the +2 stroke?
mixmasterjay
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:52 am
ive got a steel rienforced gasket set , the squish seems fine , no slap or anything , it was doing this with the old normal crank in too but not as bad , thats why i bought all this to see if it was the old setup plus the crank was going rusty lol
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:55 am
Well if it was already doing it and you have replace all that then its has to be the carb lol
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:57 am
Have you got another Carb you can try Jay ?
mixmasterjay
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 7:58 am
but it does it without the carb and exhaust on so thats ruled the carb out really lol
PostSubject: Re: serious engine probs :(   Sat Jun 04, 2011 8:00 am
No mate
Think That's just normal back pressure
Normally that would cause the fuel to feed the engine an so forth
mixmasterjay
no the other carb is fubar'd i think lol , its fueling fine but its all getting blown out the carb rather than sucke into the cylinder , its sprays out the carb its blowing that strong lol
mynameismud76
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 8:53 am
Perhaps the head has been machined wrongly? It's hard to say..
Anyhows, I've posted your question here:
http://team5hite.forumup.com/viewtopic.php?p=36075&mforum=team5hite#36075
Ian Oddie (http://team5hite.forumup.com/profile.php?mode=viewprofile&u=127&mforum=team5hite), UK champ (on and off road) is a engine guru that frequents the forum.
Another guru TMR Performance (http://www.5thscaleracingforum.com/vb/member.php/1915-TMRperformance) is another person to try.
mixmasterjay
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 9:05 am
thankyou mud mate , i will keep an eye on it lol , its really doing me head in now , had another few hours on it again today completly stripped and rebuilt the engine and carb and its still the same , even treid 2 head gaskets lol and nope that didn't work either lmao
mynameismud76
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 9:08 am
Welcome buddy.
Sounds mad, but so is this problem...but have you tried flipping the head around? Or does that not fit?
It is frustrating as hell man...bad ju ju.
mixmasterjay
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 9:11 am
yeah tried everything mud :( it does the same thing whatever lol , its not a new head its the one ive always had and it started to do it with the old crank in hence replacing its guts but noooooooooooooo its still does it well even worse tbh lol
mynameismud76
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 9:15 am
Errrr..really strange man..
Have you tried swearing at it?
mixmasterjay
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 9:16 am
yeah also tried kicking, stabbing and a poo stick but nothing seems to work
mynameismud76
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 9:19 am
Trying to visualise it, but it's tough, as engine strip down isn't done that often. Changing the ring, and that's only done every 25 litres or so.
mixmasterjay
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 9:21 am
its had about 10 strip clean and rebuilds this past 2 days lol all done buy the book to so nothing internally is out of place or in wrong
PostSubject: Re: serious engine probs :(   Sun Jun 05, 2011 9:25 am
I can see the problem right there Jay.....
You're cleaning it too much, lol.
Man Love hasn't run since last T-Party, but I bet if I put a tank of fuel in it, it would fire up and run perfectly wink british flag
PostSubject: Re: serious engine probs :(   Today at 11:35 pm
Page 1 of 4Go to page : 1, 2, 3, 4  Next
» Coborn Engine
» 5.3 LS Vortec Engine and 4L60E Transmission
» Engine of chaos ideas (?)
» Identification of Lister Engine
» Your Engine Pics
